2012 Focus Seat Belt
757 5
Hi guys,
I just bought a 2012 Focus that was in a front end collision and I just realized that it will also need a new driver side seat belt. Does anyone know what other ford models and years have the same belt? thanks
1 - 6 of 6 Posts
Interesting.
Was it the belt system itself that was identical? Or did you replace the latch assy.
I've seen conflicting info. on this, it looked like the new belt systems might be different.
Discussion Starter · #5 ·
I didn't change anything other then the sensor plug, it bolted right up. The mechanism is very similar and it has the same mounting bracket. the part that mounts to the pillar was actually identical and the buckle fastener on the 2003 has two holes, as oppose to one large hole on the new one but it still buckles up to the 2012 latch. The two door Focus has a completely different seat belt system so maybe that's where the conflicting info comes from. I also found a 2007 focus 4 door sedan that didn't have the sensor plug at all, the belt system was the same and the pillar mounting had a different look to it.
here are images of the 2012 belt system, let me know and i will take some photos of the one i installed.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Wouldn't have guessed an '03 would be similar enough to be OK (with plug swap) while an '07 wouldn't!
Makes sense that a hatch would be different.
1 - 6 of 6 Posts
