1 - 4 of 4 Posts
I have a 2012 focus SE with an intermittent no start no crank. I've noticed that it starts when the P on the gearshift indicator is lit. Sometimes it is not lit and at that point it will no start. Please help!!!
Old Phart
Moved to the MkIII Problems section.
Look at TCM issues here, 14M02 warranty extension and also at similar questions in the MkIII section.
Thank you. I have checked my grounds and fuses and relays and ignition switch and ignition cylinder and battery. Everything is working fine. When the car starts its as if nothing was ever wrong. It drives fine with no check engine lights or transmission issues but when I park I sometimes the gearshift PRNDL indicator does not light up as if the computer doesn't think the car is in park and the car doesn't start. It sounds like it has to be the computer or TCM as suggested but I sure hope it's like a lose wire or something simple of that nature...
Old Phart
Actually, a TCM would be the better deal as it would be a warranty job.
"Loose wire or something simple" would cost you for diagnostic time & repair.
1 - 4 of 4 Posts
