1 - 5 of 5 Posts
Had an accident and had to replace the doors on the left side. The body shop ordered the correct doors with the one touch system. Everything is working, but the one touch system. Any thoughts on how to reset the window controls for this to work ?
Moved to the MkIII section.
IIRC this reset needs to be done whenever the battery is disconnected, and it's just a matter of running them down with a "hold" at the bottom for a sec., then running them up & holding it there for a sec. as well. Owners of your model can correct that with exact details.
Thanks ! Found the instruction in the owners manual under the battery disconnect reset just as you said !
Crazy thing....this happened to me about a month ago. One morning I got in the car and the one touch feature wasn't working. It worked the night before. So all day I was perplexed what might be the cause of this. Then the day after that, the one touch was working again. Bizarre.
"Windows" system....
(Couldn't resist)
1 - 5 of 5 Posts
