This isn't a big deal, but do they still use the Duratec class of engines in the new 2012 Focus (which has a higher compression rate than the previous models, among other changes) or is this a new engine from Ford?
Also, not sure what changed, but if you go to fordparts.com and lookup engine assembly, there is a change as of April 14th. This for the entire engine assembly and not for the short block.From what I've read and researched, it is the same class of engine and the bottom-end is just an evolved 2.0 block and all the new tech (direct-injection, etc.) is involved in the top-end. Only wish the compression was lower for a more comfortable addition of forced-induction... But yes, the Duratec in the 2012 is just an evolution of the Duratec before it... Much like other evolutions before it where old tech was blended with new (think 302 with a carb being replaced with 302 using electronic fuel injection in the old 5.0's).
Me neither! Just thought it was worth mentioning, as there is a difference according to Ford.OK, I guess I'm not quite sure what you mean here... my car's manufacturing date was on/around July 1, 2011 (very recently).
The transmission is a dry clutch system. What you are hearing is the clutches engaging and disengaging. It won't ever go away, it's normal. You don't hear it when you accelerate rapidly because the clutches engage and disengage much more rapidly but it still makes the grinding sound if only for a split second.One other question.... a trans question:
I've got the 2012 with the SelectShift option (don't know if this matters to my question), but when I accellerate slowly, I noticed that going from 1st to 2nd, it sometimes will make like a quiet but audible grinding noise (sort of like if you were to grind gears in a true manual a little). Is this normal?
It won't do this if I accelerate moderately or fast. Only when I do a slow acceleration--meaning when I accelerate at a rate of about 5 mph per second or less.
I'm just concerned that the trans sounds like it's grinding a bit. Or maybe it's just me having to get used to a dual-clutch system and the sounds is makes.
I know many other people said that it will take about 300-500 miles for the trans to start shifting "normally" and not be as jerky, which it isn't too bad right now, as long as I don't just creep along. I guess I do have the 60mo/60k mi engine warranty so maybe I shouldn't worry for now I guess. I'd imagine if it was doing damage, that it would do something horrible within the warranty (hopefully if that was the case).
Anyone else experience this sort of noise??
Hi, you guys must be crying out for the ecoboost...I figured. I think part of the way they were able to get 160 hp from the 2.0L engine was to increase compression from 10:1 to 12:1, and that seems about right.
Everything I've read says that the PowerShift in the Focus uses wet clutches, and the Fiesta uses dry. Can anyone confirm this? Are they both actually dry clutch systems?The transmission is a dry clutch system
Clutch != sumpFord's Powershift is most definitely a dry sump system. VW's DSG is wet sump.
The Fiesta and Focus are both dry clutch systems. Coming from a wet clutch DSG in my VW I can tell the difference. The VW was much smoother. I won't miss the $400 DSG fluid service every 40k miles though. The dry clutch is also more fuel efficient. Hopefully Ford will release a software update to improve the shift quality. I had 1 or 2 from VW for the DSG. The transmission is really the only part of the car that doesn't come off as super refined.Everything I've read says that the PowerShift in the Focus uses wet clutches, and the Fiesta uses dry. Can anyone confirm this? Are they both actually dry clutch systems?
EDIT: Also, grinding noises are not normal. It is an automated manual, so some clunks, clicks, whirs and the like are expected. But they should be pretty unobtrusive. A grinding noise like clashing gears in a manual transmission? I'd certainly have the dealership check that out.
Thank you for the clarification.The Fiesta and Focus are both dry clutch systems. Coming from a wet clutch DSG in my VW I can tell the difference. The VW was much smoother. I won't miss the $400 DSG fluid service every 40k miles though. The dry clutch is also more fuel efficient. Hopefully Ford will release a software update to improve the shift quality. I had 1 or 2 from VW for the DSG. The transmission is really the only part of the car that doesn't come off as super refined.
