This is my wife’s car and I’m never in it unless it’s time for oil change etc. She drove my truck today so I could check out the car getting it ready for inspection and new tags this month. It seems everything went south since the last oil change. I noticed it idled bad right away and as I pulled it over to my shop when I hit the brakes I could here them and feel them. She never said a word. It threw a code P0420. Catalytic bank one. Did the same thing last year and I found some stuff called Cataclean. Fallowed the instructions and the code cleared itself and the car ran a lot better. I told her then we need to keep an eye on it. Now I’m also getting ignition timing advance for #1 cylinder. 9BTDC I thought I may have done something wrong today either with the scanner or some how when I checked the tensioner on the belt because I turned the tensioner by hand while holding it with a 14mm wrench. It didn’t want to turn the belts starting to fray. When it did turn so did the belt and out of the corner of my eye I saw the crank pulley turn as well. I’m Mr. DIY with a new scanner I’m still learning about and haven’t dealt with a timing issue in so long back then you popped the hood and turned the distributor by hand and hope it didn’t have a small crack in it because……well it doesn’t feel very good ask me how I know.
So I have to do a brake job. replace the belts and tensioner AND valve cover gaskets leaking now. Not to mention what I had planned on doing as far as maintenance.
So I broke down and went online to an ask an expert site and got ahold of a Ford mechanic to verify what I was thinking. Catalytic bank one and missing at idle. Evidently the #1 cylinder. He agreed catalytic converter is clogged. I don’t think I’ll get away with pouring something in the tank although it did work well last time. It should at $30 a pop. So it looks like I’m doing the catalytic converter change before it really messes up the engine. Sorry for the long rant but I’m almost finished up with my boat I’m rebuilding. Just have to finish wiring and get it wet. It’s took a year.
Anyway has anyone ever replaced the catalytic converter on a Focus? What do I have to look forward too? It seems all bolt on from the manifold with no welding but I could be wrong it’s happened twice before.
Thanks for reading my bad day and believe it or not there’s more. Lol
