I have a 2011 SES with an automatic transmission. I have a 120 mile round trip commute for work and I make that trip 6 days a week. That out of the way, my car has a lot of miles on it for its age.
My tires have aprox 15,000 miles on them and I rotate and balance them regularly. My car has recently had the front end aligned. I replaced my front brake pads and rotors about 5,000 miles ago as well as my front stabilizer bar end links.
Now, onto my issue... Ive recently noticed a very faint noise which seems to be coming from the right front, almost sounds like a faint power steering pump whine when it is low on fluid but I do not hear the noise unless I am driving. I've checked my all my fluids, belt, and tensioner pully and they seem fine. Also worth mentioning, the noise does NOT change with engine RPM but rather with the speed of the car.
This morning on my way to work, I turned the air and the radio off, I was running 65mph on a very smooth, freshly re-paved portion of I-35, I let off the gas, placed the car in nuetral and listened. As my speed went down, the noise changed pitch slightly, I then placed the car back in drive and accelerated back to 65 and the noise resumed the original pitch I heard. I hear the noise from 10mph to 80mph.
Do you think it could be the front wheel bearings? If not what else should I check?
If so, where is the best place to buy them? I'll be replacing them myself.
Also, if I tear it down that far, should I do lower ball joints and inner/outer tie rods?
:: Obligatory photo of said car ::[unsure]
