1 - 2 of 2 Posts
So my focus has had a small power steering leak for a bit now. It appears to be coming from the reservoir so I'm betting the o-rings are bad or the plastic has a crack (kinda rare but I've seen worse).
So, would I have to remove the PS pulley to replace the reservoir or do you think I can do it all without pulling the pulley? Just wondering if anyone has done this bit.
Thanks
Hey there was just searching online and came across your question. I just replaced the pressure line on my 08, and I took the reservoir off without having to remove the pulley. I actually replaced the line without taking it off also. It is do-able.
Remove the coolant overflow bottle, it makes it a lot easier also.
1 - 2 of 2 Posts
