1 - 2 of 2 Posts
Trying to change passenger side wheel bearing but can't get the bolt out of the lower ball joint. Tried heat, beating, Just won't budge at all,
cant get the pinch bolt out the spindle or cant get the ball joint out the spindle once pinch bolt is out? if you're having trouble with the pinch bolt, hold the torx part of the bolt and spin the nut, then punch out the bolt.
1 - 2 of 2 Posts
