After my last thread on here and doing some digging elsewhere, I replaced the shifter as suggested and replaced the starter related fuses as a precaution.
It starts, but won't shift out of park. Doing so with the override, reverse doesn't seem to work. Would an issue with the selector lever wiring harness cause that too?
Both issues came up at the same time, so it seems likely that they are connected. Section 307-05 of the workshop manual talks about checking for an open and a ground issue on the vehicle side of the harness, but doesn't talk about where it connects in much detail. It is up by the ignition switch in the steering column or is it around the junction box on the drivers side?
