1 - 7 of 7 Posts
Greetings,
I have a 2010 focus, 134,000 miles. Automatic 2.0 SES. I was hearing a clunking noise coming from the rear end so I took it to the dealer. They said they knew what was wrong---sway bar links gone bad. I decided to re do the entire rear end to make sure the problem was fixed. struts, sway bar links, etc. I replaced all 4 struts and shocks on the car and the sway bar links and had it aligned. Sure enough, noise is still there. It's gotten a little better, but I sitll hear it when I go over a big bump in the road. Does anyone have any idea at this point what it could be? thank you My opinion is it is the exhaust...it hangs on those hangers and it sounds like it is swinging around hitting the car when I go over a bump? rotted bushing?
One of the first things you are going to be asked here is whether you have actually looked under the car yourself? Nobody can help diagnose over the internet without knowing any facts about your car. Get down and look at every part of your exhaust that you can see, then report back what you have found. Unless you have a great relationship and know you can trust your dealership, I would never recommend going to them with something you have not at least looked at yourself. I can only imagine what all they did cost you, unless you have no way to do any of it yourself it's too much. I am saying this from experience, before I was comfortable working on the focus I had. It's especially frustrating when your issue is still not resolved after throwing parts at it. Good luck, please report what you eventually find is the issue.
Not sure if this would be the same as your mk2, but on my 2007 I had a squeak over bumps before, turned out to be the brake cables were rubbing on the brackets holding them in place just before the rear wheels. Rubbed through the rubber til it was metal on metal.
thanks
Hello,
First of all thanks for answering everyone I appreciate it!!
Sparky34kv :
yes I have looked under the car. everything looks fine to me. I am not great with suspension stuff but it all passed the eyeball test. everything was connected and in place and nothing looked rotted or loose or broken. I do have a good relationship with my dealer. I had a major engine repair a few years ago they gave me the parts at cost. When I had the struts and shocks replaced, I told them I had $1000 to work with and they took 15% off the cost to fit my budget. Belle tire was quoting me over $1100. The exhaust seems to be ok, I followed it as far as I could. However, it is very loose, I can take my hand and grab the tailpipe and smack it up against the bottom of the car BAM BAM.. Again, it LOOKS OK but it is very loose.
appsbyarron : this seems to be the general consensus for this problem, sway bar links. However, those were replaced along with all the struts and shocks. still have the same noise problem.
cwrob95: have also seen a few posts about the brake cables. I will have to look into this.
going back to dealer next week, will let you all know what they say and thanks again
If you can bang the exhaust against the car, it's too loose and very likely the sound you're hearing. There are several hangers, but usually it's the rearmost one where the rubber rots out (or it rusts off the mount, but you would have seen that).
Looks mean very little with suspension parts unless they're actually cracked, which is rare. Any of your four control arms on either side could have worn rubber bushings that would look fine but show excessive movement when a pry bar is applied.
My 2008 Ford Focus (north american model ) ( so same gneration 2008-2011)
Had squeaking going over bumps a lot.
1-replaced lower rear control arm ( bushings weren't great ) replaced around 7-8 years old and 47,000 kilometers
2- as someone mentioned at 30,000 kilometers (im in canada) the front sway bar links went , replaced with aftermarket greaseable moog's. 67,000km at present may 2019 and no issues thus far.
3-Your rear trailing arm bushings may be going -- i have to replace mine -- going with aftermarket moog part #k200064 -- ford won't sell you just the bushing , they want to sell the entire trailing arm & bushing assembly together which is like $200+.
4- Front Lower Rear Control Arm bushings are common on Focuses
i am going to have to do that on mine at present , and go with moog or oem ford.
also i know some people say the parking brake can cause squeaking issues on the focus. there is a guy on youtube doing a video on that i think.
Have all those checked out and probably one of them will be the culprit.
Bushings of some kind is likely the answer.
1 - 7 of 7 Posts
