It's "hidden" (grin)
You have to crawl underneath & peek up between the fuel tank & the rear suspension...
All "should" be obvious from there...
Wrench to remove holder, & push the clips IN, then push fuel lines IN B4 pulling out to remove the tension on them. MIGHT have to push in to push clips in...
Pulling the fuse (fuel pump) & letting it run 'till it quits will reduce the "gas in the face" effect.... Alternatively, the wire to the collision cut-off at the right foot well can be disconnected for the same effect...
Luck!
P.S. - As it sounds like you've learned by now, the ONLY "dumb" question is the one you SHOULD have asked.... (grin)
