I was wondering if someone could tell me where the Central Timing Unit is and supply a wiring diagram of it. I installed LED Signals and im trying to see if i can install a LED flasher relay by pulling the pins for the flasher control to bypass the factory Flasher control and see if they will work or if i need to install a LED flasher relay inline with the factory flasher control. Im trying to avoid using load resistors i don't really care for them they tend to generate alot of heat and plus im not really trying to splice my wires to install them.
