Hey man.. thanks... it has 10100K on it right now.. I bought it with 9200... and no I have not messed with it... as much as I would love to mod it.. I do not.. its all under warranty so I do not want to void anything.How many miles are on it?
Have you messed with this engine before?
What was wrong with the tumbe flaps? What did they do to them? I guess they could hang up but ide think the diaphram would maybe be the issue. Mine has about 55k and they seemed pretty solid when i took mine apart.Hey man.. thanks... it has 10100K on it right now.. I bought it with 9200... and no I have not messed with it... as much as I would love to mod it.. I do not.. its all under warranty so I do not want to void anything.
The other night I was driving it and when I went to leave a light.. it started to bog out.. like it wasn't getting any air or if the trans was crapping out. I pulled over.. turned it off.. sat for a little bit... turned it over.. and it took right off. It hasn't done it again since.
The car gets good mileage. I am averaging about 27-28mpg all city, 33-34mpg between work and home and during a 400 mile trip back and forth all highway I got about 35-36mpg.
Overall... pretty happy with the car but I think it has a tick similar to my old 07. If it is the Tumble flaps... I obviously want to get them replaced ASAP because when I had it fixed in my 07... I got better MPG.
Does anyone know about how to test the IMRC on electronic TB version of the 2.0 to see if the IMRC is working or not?
would removing these help/hinder performance in anyway?[scratch]yeah the 09 has tumble flaps. There is a diaphragm connected to an arm that controls the flaps. It's run on a vacuum. It's on the side of the mani next to the TB.
I just did it to mine. I bought a second IM and then took em out and plugged all the holes.would removing these help/hinder performance in anyway?[scratch]
They were stuck closed... not sure if it was all of them or just one of them... but it caused a loud clicking noise... I thought it was a bad valve or lifters but the guys in here said this 2.0 engine does not have a traditional lifter arrangement. It was loud enough to hear while parked but not really in the car. The dealership took it too swore that it was loud fuel injectors and even replaced 2 of them but the noise was still there. After I took it to another dealer... they fixed them and the noise was gone. The car ran better and got better MPG. I got rid of the 07 because I thought I had overran a gear... it just wouldn't shift the same after some time and I didn't want to be eventually on the hook for a MTX clutch or trans. The same dealership that fixed it for me gave me a great trade in and I took it. I got an 09 with ATX now and I THINK it might have the same issue because it ticks at start up and this time I can hear a ticking in the car while under throttle too. The car get great MPG's still but I think it could so better.What was wrong with the tumbe flaps? What did they do to them? I guess they could hang up but ide think the diaphram would maybe be the issue. Mine has about 55k and they seemed pretty solid when i took mine apart.
You would need a tune and you would probably lose some bottom end.would removing these help/hinder performance in anyway?[scratch]
Just a thought. It is often cited that the loss of low end torque for aftermarket intakes is due to the shortened runners. But now I am wondering if it is mainly due to the loss of the tumbler flaps (which are a part of the OEM intake). [scratch]You would need a tune and you would probably lose some bottom end.
Yeah i dont think it is the length. My hope was that by removing them i got the slight performance increase of the cossie but with the longer runners.Just a thought. It is often cited that the loss of low end torque for aftermarket intakes is due to the shortened runners. But now I am wondering if it is mainly due to the loss of the tumbler flaps (which are a part of the OEM intake). [scratch]
Does it do this when the engine is cold? Like it has sat all night and you are starting it up in the morning to go to work? If so, my car does this and I have been assured that this is normal and this noise was duplicated on a focus that was also an 08 with similar miles as mine. I would still take it in and leave the car with them for a good 24 hours at least.I THINK it might have the same issue because it ticks at start up and this time I can hear a ticking in the car while under throttle too. The car get great MPG's still but I think it could so better.
I dont know how you would wire it but it is a cool idea having the runners change in length as needed.Ya'know, the other thing I have always wondered is, would the D20 benefit from the the D23 intake if you could wire the runner control. I always assumed that they were not included due to cost. Per the info provided by TB1999 (http://www.focusfanatics.com/forum/showthread.php?t=238575), maybe the magic bullet is to employ the D23 intake with runner control, but without the tumble flaps. Although I think we would have to have to have Toms input for any sane answer.
Hmmm. This is interesting! Per my 2007 wiring diagram. The "Tumbler Flaps" as we call them official name is "Intake Manifold Runner Control (IMRC) module". Then ONLY on the 2.3L (with manual transmission(?)), There is a "Intake Manifold Tuning Valve (IMTV)". Now per above, the wire to the IMTV solonoid is the same as the IMRC solonoid. So there isn't any special wiring.I dont know how you would wire it but it is a cool idea having the runners change in length as needed.
Well i thought the runner control works like the tumble flaps, lower RPMs the flaps close down on the 2.0 and on the 2.3 the runner control puts the runner in the long mode. As the RPMs increase the tumble flaps open up and on the 2.3 the runner control switches to the short runner mode.Hmmm. This is interesting! Per my 2007 wiring diagram. The "Tumbler Flaps" as we call them official name is "Intake Manifold Runner Control (IMRC) module". Then ONLY on the 2.3L (with manual transmission(?)), There is a "Intake Manifold Tuning Valve (IMTV)". Now per above, the wire to the IMTV solonoid is the same as the IMRC solonoid. So there isn't any special wiring.
I thought i read something about it not having the sensors or something to run the IMTV? something about the ECU or something not working with this IM?Hmmm. I would think you would want the IMTV valve to be functional as you want a shorter runner higher into the RPM range. The vacuum lines could be the same/shared.
What I don't know is if the D2.0 would actually get any benefit as the head is different.
Good one to ponder?
