My 2009 focus was the victim of my son hooking a battery in backward. I have found most of the blown fuses I need a charging wiring diagram. The battery light is on an I have 1.2 volts on the battery wire to the alternator. I need help. thanks
I would have someone check the system with a computer. The electronics in the car are probably fried. It will show all the errors and then you can go from there.
As for the manual I'd wait some time until some other member pops up with that info. If not, there are cheap manuals on ebay ~$50.00
It had blown the 200 amp main fuse and about 5 other small fuses. I had to replace the big fuse in the engine compartment. She is back on the road. Thanks
Hi.
Recently noticed horn had stopped working but when I pressed it the lights flash too. Also one head light is out. Bulb is ok as it flickers when turning lights on. I'm assuming the problems are connected. Anyone had a similar problem and any ideas of what to do to sort it out.
Thanks
So I am pretty sure my motor mount went out again I uh, kinda have an issue with hitting pot holes from time to time and theyre pretty big ones either way i had my buddy get in my car today and hold my break down amd put my car in drive and I orignally thought the noise was coming from my trans...
Hello, I have a 2010 SEL with a 5 speed manual with about 125,000 miles. I'm going to be replacing the clutch soon and was planning on installing the Phoenix stage 2 kevlar clutch kit. But something that I haven't been a fan of for the first month of owning the car is how long the RPMs stay up...
Can someone with a service manual tell me what the fuel pressure should be on a 2008 - 2011 ford focus 2.0? I can't find the spec or manual anywhere.
It would help a lot! Thanks!
