1 - 1 of 1 Posts
16 Record(s) Displayed.
Report Date : November 13, 2011 at 06:50 PM
Search Type : VEHICLE
Year : 2009
Make : FORD
Model : FOCUS
Make : FORD Model : FOCUS Year : 2009
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Number : SIS-21841 Date of Bulletin : APR 01, 2011
NHTSA Item Number : 10038965
Component : ELECTRICAL SYSTEM: SOFTWARE
Summary :
COMM-TRANS LUND: SOME 2009-2011 MODELS MAY HAVE THE AIR BAG INICATOR FLASHING WITH A STORED TROUBLE CODE. THIS IS A SOFTWARE PROBLEM. *RM
Component : AIR BAGS
Summary :
Service Bulletin Number : AS-21769 Date of Bulletin : MAR 01, 2011
NHTSA Item Number : 10039053
Component : POWER TRAIN
Summary :
FORD: IF THERE IS AN INTERMITTENT LACK OF POWER, SURGE, OR HESITATION WHILE DRIVING THE BRAKES WILL OVERRIDE ACCELERATION. *RM
Summary :
Component : ENGINE AND ENGINE COOLING:ENGINE
Summary :
Component : SERVICE BRAKES, AIR:ANTILOCK
Summary :
Service Bulletin Number : SB-21510 Date of Bulletin : SEP 01, 2010
NHTSA Item Number : 10037092
Component : VEHICLE SPEED CONTROL:CRUISE CONTROL
Summary :
FORD: ONE SOME 2008-2010 FOCUS VEHICLES THERE MAY BE AN INOPERABLE SPEED CONTROL. *RM
Service Bulletin Number : TB-21400 Date of Bulletin : JUL 01, 2010
NHTSA Item Number : 10034586
Component : WHEELS
Summary :
FORD: EQUIPPED WITH 17 INCH WHEELS ONLY; STEERING FOLLOWS ROAD IRREGULARITIES AND/OR RUTS. VEHICLES MAY EXHIBIT THE VEHICLE'S STEERING SEEMS TO FOLLOW ROAD IRREGULARITIES. FIRST, COMPARE TO A SIMILAR VEHICLE UNDER THE SAME ROAD CONDITIONS. IF COMPARABLE PERFORMANCE IS EVIDENT, CONSIDER THIS NORMAL CHARACTERISTIC OF THE VEHICLE AND NO REPAIRS SHOULD BE PERFORMED. *PE
Component : STEERING
Summary :
Service Bulletin Number : TB-21399 Date of Bulletin : JUL 01, 2010
NHTSA Item Number : 10034585
Component : TIRES
Summary :
FORD: PREMATURE FRONT/REAR TIRE WEAR AND/OR VEHICLE DRIFT ON WET OR SNOW COVERED ROADS. IF PERFORMING AN ALIGNMENT, RECORD ALL ALIGN-MENT ANGLES PRIOR TO ANY ADJUSTMENTS, AND ENTER IN WARRANTY CLAIM IF APPLICABLE. *PE
Service Bulletin Number : TSB-20932 Date of Bulletin : AUG 01, 2009
NHTSA Item Number : 10030834
Component : ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary :
FORD: SOME VEHICLES MAY EXHIBIT A PARTS NO CRANK/NO START CONDITION WITH DIAGNOSTIC TROUBLE CODES 9DTC) P1260 IN THE POWERTRAIN CONTROL MODULE (PCM) AND U0100 IN THE INSTRUMENT CLUSTER (IC). *PE
Component : POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary :
Service Bulletin Number : TSB-08-22-2 Date of Bulletin : FEB 01, 2009
NHTSA Item Number : 10027912
Component : FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Summary :
FORD: VEHICLES MAY EXHIBIT A MALFUNCTION INDICATOR LIGHT (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0456 (VERY SMALL EVAPORATIVE EMISSION SYSTEM LEAK DETECTED; VERY SMALL LEAK 0.020" (0.51 MM) DIAMETER). *PE
Service Bulletin Number : TSB-0819-9 Date of Bulletin : SEP 01, 2008
NHTSA Item Number : 10027986
Component : STEERING:HYDRAULIC POWER ASSIST SYSTEM
Summary :
FORD: SOME VEHICLES BUILT ON OR AFTER 10/3/05 MAY EXPERIENCE A CUSTOMER CONCERN OF THE POWER STEERING (P/S) SYSTEM LEAKING AND/OR SYSTEM NOISY. *PE
Component : STEERING:HYDRAULIC POWER ASSIST:pOWER STEERING FLUID
Summary :
Component : STEERING:HYDRAULIC POWER ASSIST:pUMP
Summary :
1 - 1 of 1 Posts
