1 - 3 of 3 Posts
Where exactly is the fuse panel located and how do I access it? I need to find it to pull the fuse for the sync. I am having problems where it plays music from my thumb drive but there is no sound.
Discussion Starter · #2 ·
Ok, I found it. They really don't give you much room to get at it... So I pulled the fuse for the Sync system and it now works. This thing works about as good as Windows 95.
Almost sounds like a configuration issue with the Sync itself. Did you read the manual on the Sync system? This will tell you how to configure the system to play music through the USB port.
1 - 3 of 3 Posts
