1 - 3 of 3 Posts
SERVICE BULLETIN:AS-21769 NHTSA ITEM NUMBER:10039053
MFG Bulletin Date: 03/01/2011
Component: SERVICE BRAKES, AIR:ANTILOCK
Bulletin Summary: FORD: IF THERE IS AN INTERMITTENT LACK OF POWER, SURGE, OR HESITATION WHILE DRIVING THE BRAKES WILL OVERRIDE ACCELERATION. *RM
Date added to database: 07/06/2011
0 Child Safety Seat Reports No Reports
1 Electrical System Reports Read Now Close
Yes, include on Custom Report SERVICE BULLETIN:AS-21769 NHTSA ITEM NUMBER:10039053
Component: ELECTRICAL SYSTEM: SOFTWARE
1 Engine and Engine Cooling System Reports Read Now Close
Component: ENGINE AND ENGINE COOLING:ENGINE
1 Equipment Reports Read Now Close
Yes, include on Custom Report SERVICE BULLETIN:SI-20010 NHTSA ITEM NUMBER:10032234
MFG Bulletin Date: 10/01/2007
Component: EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
Bulletin Summary: FORD: SOME MULTIPLES VEHICLES REPLACEMENTS MAY REQUIRE REVISED AS BUILT DATA. THE NEW LEVEL SJB SERVICE PART INTRODUCED BETWEEN 10/07 AND 02/08 WILL REQUIRE ENTRY OF AS BUILT DATA. *PE
Date added to database: 02/24/2010
1 Fuel, Exhaust, Emissions Control Reports Read Now Close
Yes, include on Custom Report SERVICE BULLETIN:TSB-08-22-2 NHTSA ITEM NUMBER:10027912
MFG Bulletin Date: 02/01/2009
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Bulletin Summary: FORD: VEHICLES MAY EXHIBIT A MALFUNCTION INDICATOR LIGHT (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0456 (VERY SMALL EVAPORATIVE EMISSION SYSTEM LEAK DETECTED; VERY SMALL LEAK 0.020" (0.51 MM) DIAMETER). *PE
Date added to database: 02/19/2009
1 Interior System Reports Read Now Close
Yes, include on Custom Report SERVICE BULLETIN:SB-21510 NHTSA ITEM NUMBER:10037092
MFG Bulletin Date: 09/01/2010
Component: VEHICLE SPEED CONTROL:CRUISE CONTROL
Bulletin Summary: FORD: ONE SOME 2008-2010 FOCUS VEHICLES THERE MAY BE AN INOPERABLE SPEED CONTROL. *RM
0 Lighting and Communications System Reports No Reports
1 Misc. Component Reports Read Now Close
Component: UNKNOWN OR OTHER
3 Power Train Reports Read Now Close
Component: POWER TRAIN
Yes, include on Custom Report SERVICE BULLETIN:08-5-8 NHTSA ITEM NUMBER:10024825
MFG Bulletin Date: 03/01/2008
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Summary: 4R27E TRANSAXLE NO 3RD OR 4TH GEAR--BUILT ON OR BEFORE 1/29/08. *NJ
Date added to database: 05/30/2008
Yes, include on Custom Report SERVICE BULLETIN:TSB-08-9-3 NHTSA ITEM NUMBER:10026384
MFG Bulletin Date: 10/23/2008
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Bulletin Summary: FORD: MIL ON DTC P0128/ DELAYED 3-4 UPSHIFT/IMPROVED HILL HOLD. BUILT ON OR BEFORE 4/18/08. VEHICLES MAY EXHIBIT A DELAYED 3-4 UPSHIFT/MALFUNCTION INDICATOR LAMP. *PE
Date added to database: 10/23/2008
3 Steering Reports Read Now Close
Yes, include on Custom Report SERVICE BULLETIN:TSB-0819-9 NHTSA ITEM NUMBER:10027986
MFG Bulletin Date: 09/01/2008
Component: STEERING:HYDRAULIC POWER ASSIST SYSTEM
Bulletin Summary: FORD: SOME VEHICLES BUILT ON OR AFTER 10/3/05 MAY EXPERIENCE A CUSTOMER CONCERN OF THE POWER STEERING (P/S) SYSTEM LEAKING AND/OR SYSTEM NOISY. *PE
Date added to database: 02/25/2009
Component: STEERING:HYDRAULIC POWER ASSIST:pOWER STEERING FLUID
Component: STEERING:HYDRAULIC POWER ASSIST:pUMP
0 Structure Reports No Reports
2 Suspension, Wheel, Tire Reports Read Now Close
Yes, include on Custom Report SERVICE BULLETIN:SI-20014 NHTSA ITEM NUMBER:10032235
Component: TIRES
Bulletin Summary: FORD: SOME VEHICLES MAY EXPERIENCE A SLIGHT TIRE SHAKE OR VIBRATION CAUSED BY TEMPORARY TIRE FLAT SPOTTING. IF TIRE SHAKE/VIBRATION IS EVIDENT AT PRE DELIVERY OR VERY LOW MILEAGE DRIVE THE VEHICLE FOR 10-15 MILES PRIOR TO ATTEMPTING ANY R
You can get EVERY Technical Service Bulletins (TSB) in its entirety ever issued by the manufacturer to its dealers for this model car plus ALL future TSBs issued for the next 12 months. [Purchase Full TSB Reports] [What you'll get] [What is a TSB]
Yes, include on Custom Report SERVICE BULLETIN:TB-21399 NHTSA ITEM NUMBER:10034585
MFG Bulletin Date: 07/01/2010
Component: TIRES
Bulletin Summary: FORD: PREMATURE FRONT/REAR TIRE WEAR AND/OR VEHICLE DRIFT ON WET OR SNOW COVERED ROADS. IF PERFORMING AN ALIGNMENT, RECORD ALL ALIGN-MENT ANGLES PRIOR TO ANY ADJUSTMENTS, AND ENTER IN WARRANTY CLAIM IF APPLICABLE. *PE
Date added to database: 12/08/2010
1 Visual System Reports
Yes, include on Custom Report SERVICE BULLETIN:07T08-S1 NHTSA ITEM NUMBER:10024304
MFG Bulletin Date: 01/18/2008
Component: VISIBILITY:DEFROSTER/DEFOGGER SYSTEM
Bulletin Summary: 2008 FOCUS DEFROSTER PERFORMANCE UPGRADE PRIOR TO SALE - PARTS UPDATE. *NJ
Date added to database: 04/03/2008
Shiny Metal Titanium
I think thats an option in the menu for autolock
Look up autolock in your manual for the exact procedure to get to the menu on the info screen between the speedo and tacho
1 - 3 of 3 Posts
