I have a 08 Focus that was wrecked and I removed the complete interior inc. A//C box. Everything worked prior to removing and after recharging the A/C system the compressor won't come on. I can jumper the relay connectors in the underhood fuse box and it runs. I was told that some models you have to cycle the key to reprogram the PCM???
I also have a airbag light on after replacing all the bad componets inc. the module. I was told on this problem that when you remove the pass seat it has to be returned to the dealer to re-scale the seat..... Jim
