Really? You sure? How can you lift it out of the top-side if the car has an engine hood?Yes, it's possible.
Speaking of which, don't forget to mark around the hinges before you loosen them. That will help you line up the hood as it was before when you put it back on. I've used Sharpie markers, and simply scratched the outline- which is more difficult to see than the Sharpie.You always remove a car's hood to pull an engine.
I prefer some jokes without a jk or an emoticon... and was waiting for someone to say "yep, hood is in the way, so you gotta drop the engine thru the bottom".You always remove a car's hood to pull an engine.
[like]Nope, can't remove front entirely as the hidden bumper is welded in place across the frame horns.
