1 - 2 of 2 Posts
Hi,
My 2007 2.0L has about 91K on it. When the outside air temp is up above 50-60 degrees it is hard to start when engine is hot. Also when the a/c is kicked on it lacks power and does some surging under acceleration. Since I have not been able to find a tech manual for the '07 models, I don't know if these have EGR's.
Is there an EGR valve on these engines? How about PCV? If so where are they?
Any other suggestions?
Thanks
Bill
Most likely this is due to a faulty throttle body. The program will only get worse until catastrophic failure. It is similar to the Escape/Fusion problem. A dealer cannot diagnose because there are no codes to pull from the computer.
1 - 2 of 2 Posts
