1 - 3 of 3 Posts
Has anybody successfully changed the fog light bulbs on a 2007 SAP model? I tried the other day but wasn't even able to remove the splash guard...any tips?
Thanks.
has a screw loose
Posted via FF Mobile I changed mine out not to long ago. Your gonna have to get that splash guard to come off to get to them. Kinda sounds like those plastic screws are turning inside the clip that they go into. You may have to use some needle nose pliers to hold that piece and then back the screw out. I've done that on several of them that wanted to turn.
Flipping Rockstar
You can also reach the housings by removing the headlights, which was how I did it when I changed My bulbs to yellow goodness. Kind of a pain, but it did the trick.
1 - 3 of 3 Posts
