Hello everyone once again I'm turning to you guys in need of help.
I've recently purchased a clean 2007 Focus ST and the CEL was lit throwing the following codes, p0108 MAP sensor high input, p0102 MAF sensor low voltage and p2196 O2 sensor lean B1S1.
AutoZones fix finder suggests to replace or clean the EGR valve so I used carb cleaner to clean it up and it's still throwing the same codes.
I went to a local pull a part and pulled a used low mileage EGR valve and cleaned it up and replaced it and it's still throwing the same codes. I've disconnected the battery terminals to reset the CEL but it come back on once I cycle the engine.
One thing to note as I was detailing the engine bay I noticed a small vacuum leak near the intake manifold runner solenoid part # 9j559
Expering the following symptoms
Upon first start higher idle 1050-1100rpm
Then drops to around 750-800rpm and fluctuates sometimes low enough to where the engine almost stalls.
Applying gas corrects it and no issues driving.
Any help is appreciated, thank you!
