1 - 4 of 4 Posts
Wired up my 2007 SE with factory cruise. Worked first time!. The attached links made it possible. Followed the instructions to get the parts out of a 2005 for $85 (Lkq). The second page told me how to wire it up. Only change I made was to wire the cluster cruise indicator to pin 18 of the the cluster connector. Picture shows how to get the wires inside without drilling a hole though the firewall. Grab all the harness connectors (for the servo, for the clock spring and the brake pedal switches). Grab both brake switches and as much of the harnesses as you can. Hardest part was building the 8 wire harness from the end of the servo harness I got to inside the car and routing it. If you have any questions, PM me.
https://www.scribd.com/mobile/doc/82726802/Ford-Focus-00-07-Guides-for-Cruise-Control-Wiring
https://www.google.com/imgres?imgurl=http://img263.imageshack.us/img263/2087/cableroutingdiagram1hw8.jpg&imgrefurl=http://forums.focaljet.com/showthread.php/571003-firewall-drill-point&docid=lUytbFNry9ehnM&tbnid=I47oDmHrC2ygBM:&vet=10ahUKEwjq79D_2tfUAhVL6SYKHdUHAOEQMwgwKAAwAA..i&w=600&h=538&bih=512&biw=360&q=ford focus firewall hole&ved=0ahUKEwjq79D_2tfUAhVL6SYKHdUHAOEQMwgwKAAwAA&iact=mrc&uact=8
Hi Chiefbs,
The first link (scribd) says the document is removed. Do you have another link for it? I'm really interested in adding cruise to my '02, so any information I can get would be a huge help.
Cheers!
1 - 4 of 4 Posts
