I have a 2007 Focus SE 2.0L standard with 135,000 miles that up until this afternoon starts and runs with no misfires, sputtering etc. Ran this morning no problem, but now it won't start.
Battery is new, tested with a meter and working fine.
When you remove the oil cap you can see that the crankshaft is turning so its not the starter.
You can hear the fuel pump turn on, so it seems to be getting fuel.
Its my girlfriends car and she's never changed the plugs and wires, although if it was a plug, wire, or coilpack you'd think it would run crappy or misfire rather than just suddenly stop. I get no sputtering, nothing.
My next move is to pull a plug and test for a spark, but what else should I look for? Anything that needs maintenance apart from the plugs and wires that would suddenly make it not get spark suddenly?
In searching around it seems that the crankshaft position sensor would cause this. Where is it? Behind the serpentine belt?
It hasn't had the check engine light so I don't think I can get any trouble code off it because it won't start. Is there any way to read codes off a Focus that won't start?
