1 - 6 of 6 Posts
It seems I'm a bit dyslectic today, should be vac line. I'm not sure what hose hooks up here. I've looked everywhere. I've only had this car a few days and still going over it. I found this connection open and can only assume that something should be connected. HELP!!!!!
If you look down that tube there is a small rubber flap. I am assuming it is used if there if to much air to release some pressure.
There was nothing on my 2004 which has the exact same intake setup..
Thanks guys. I am going to trash this system as soon as I scape up the cash for a CAI. Still getting the P0511 error and for the life of me can't find the cause.
I may be mistaking but check the cable that plugs into your throttle body. When i replaced my intake system with K&N it got bumped loose and was giving me i think that was the same code i got. So its worth checking.
1 - 6 of 6 Posts
