1 - 2 of 2 Posts
I'm trying to find a TPS for an Automatic 2006 ZX4 ST.
The PN on the TPS I have is 988F 9B989 BB 5H15B
I seem to be able to find this except for the last part of the number (5H15B)
Pretty sure that last string is only a dating code for last time modded, meaning it indicates only that the sensor you find is a newer one than what you have. To have the same exact number you would need one made in 2006. It can be a code for the particular part vendor too. The 'BB' says the major last mod is the same. The service part number supplied in parts boxes is often NOT the same as the OEM number used on the assembly lines either. The front part will be but not the last.
The big thing with TPS is that they need to clock the same and rotate in the same direction, that should mean the part will work. Of course the connector and engagement lever must match too.
1 - 2 of 2 Posts
