1 - 3 of 3 Posts
Hi All,
I have just bought a 11/2006, South African built LS Focus Sedan, 4 Speed Auto. It's a great car and I love the driving dynamics.
However, at speed it occasionally holds onto second gear (I think). For example, yesterday I accelerated 0-80 (KM/H) (50 MPH) and held it at 80, and it stayed at around 4700RPM, only after 15 seconds did it shift gear. This was on a very slight descent.
Also, occasionally when coming to a complete stop, after half a second, it will jerk forward briefly.
Does anyone have any clues as to what might be the issue here?
Car has 80,000kms (50,000 miles) on the clock and the A/T fluid seems to be at the correct level from what I can tell. Also when I bought it the shifter was very stiff however after putting it in and out of sport (manual) mode a few times this has been fixed.
Thanks in advance :)
Discussion Starter #2
To follow up: The car seems to take ages to change back into first after coming to a complete stop, and when it does, you can feel it kick the car forward a little.
Does anyone have any clues as to fault or remedy? A/T fluid flush perhaps?
Please have your OBD scanned for codes.
I rarely promote replacing car parts without good reason... but I do make an exception when the transmission is acting up. After checking fluid level and maybe some wiring tests (dependent of symptoms) I will often recommend replacing 1 or all 6 solenoids inside the transmission; but again, dependent of symptoms. This job is fairly easy or not too difficult.
I recommend replacing the solenoids primarily because it is one of the few things we can do at home and because it has a history of fixing many trans issues. Another somewhat easy home fix is replacing the intermediate band if/when you have no 2nd and 4th gear.
Here are some links that will help you learn some more and help you decide what might be best in your situation.
http://www.focusfanatics.com/forum/showthread.php?t=169493
http://www.focusfanatics.com/forum/showthread.php?t=467129&page=5
http://www.focusfanatics.com/forum/showthread.php?t=167830&highlight=p0750
https://www.youtube.com/watch?v=l36SjcB0FuQ
http://www.ebay.com/itm/FORD-4F27E-...Parts_Accessories&hash=item3cd493997e&vxp=mtr
http://philldesigner.com.br/ecospor...ansmissao_Ford_EcoSport_TRANSMISION_4F27E.pdf
1 - 3 of 3 Posts
