Just me and the kids here tonight, an extra kid for a sleep-over too. Lucky me huh? Hey! Gotta catch the new SNL tonight, it's starting in less than an hour.
Think matey................
If the sensor is a simple one that indexes in to not be able to move like quite a few then no issue. But if SLOTTED then it most likely needs a setting.
#1...........why on earth do you people take them off to begin with??? It is a simple metal proximity sensor and cleaning it does nothing at all. The slotting if present was your warning to not touch it.
The crank and cam sensor work TOGETHER, they indicate TDC and WHICH TDC since it can be one of two there. If the PCM doesn't care the sensor will simply plug into a hole, but if like maybe that engine and no index or woodruff key to locate damper, crank, and timing chain then it may well need good close setting. Don't set and you throw off the expected 'normal' timing difference from crank to cam sensor the PCM is looking for. That can't help. You also just faked out TDC to the PCM, it may not be right now. As well, say software provides for 30 degrees of timing adjustment and you are advanced by 5 degrees because not set right, now you have 35 total and either engine pings or knock sensor detunes engine unnecessarily. The other way or retarded would have the timing then overall too slow. Or pisspoor gas mileage and you wondering why.
Basic rule of cars, pretty much anything slotted needs adjusting. End of story.
I know nothing about that engine hardly at all but if I saw slotting there I would come to an immediate screeching halt with any work I planned on there until I fully knew how to set it. Thinking there may be a specialty tool for that.
The one tooth missing means nothing, you can have error all across the width of that one tooth. Enough I'd say to put holes in pistons if you were unlucky. The actual timing point works out usually to like one side or EDGE of a tooth, the PCM notes the gap and proceeds to use the next leader edge depending on how software is set up. A quarter inch wide gap as a timing point is a disaster to a PCM, it's only a marker.
Some of your points are received as a complaint, or some kind of rant. Please lighten up and make a clear point based on the questions asked. Please?
""why on earth do you people take them off to begin with???""
Prox sensors or magnetic pick-ups DO GET DIRTY and the filth DOES lessen or prevent proper operation. Little or nothing wrong with someone cleaning a prox sensor when suspected dirty or defective. Yes, I cleaned my CPS for no reason, but it did have 9 years of gunk on it. Also, I fixed 25 or more tail wheel position sensors/systems on helicopters while only using a towel on the prox sensor.
"" The crank and cam sensor work TOGETHER""
Yes we know that. No one suggested otherwise.
""You also just faked out TDC to the PCM, it may not be right now.""
""Don't set and you throw off the expected 'normal' timing difference from crank to cam sensor the PCM is looking for""
AFAIK, Ignition timing is not altered if CKP is mis-aligned in the slots on the CKP. The PCM receives good CKP data, bad or weak CKP data, or no CKP data. It is my firm guesstimate that the exact positioning and adjustment of the CKP is done ONLY in order to provide the CKP the best physical position to "sense" the flywheel position as it turns. A slight mis-alignment of the CKP does NOT change ignition timing; mis-alignment would only lessen or kill the signal strength being sent to the PCM. If what I just said is not true; THIS is my confusion and this is why I am involved in this thread. Please help me and others better understand the reasoning of exact CKP positioning.
""Enough I'd say to put holes in pistons if you were unlucky""
Bad CKP data or no CKP data will not crash pistons into valves on this engine. That is impossible right? -because that timing is mechanically set and is completely different than the position of the CKP. However, missing or poor CKP data might cause the engine to run poorly, cause a No Start condition, set a DTC, but would not crash this engine.
Please do not turn this into an argument more than I already have. You are one of of my favorite turds. Peace. My goal was to learn something about the CKP positioning and
to get an answer to these two question->
Note to Self: Before removing CKP, clean surrounding area, then hit it with a little white spray paint to mark exact position of CKP before removing it.
^^ why is this white paint not good enough?
-and-
And to further explain or question this CKP situation; If I remove the serp belt -and- remove my CKP -and- turn the engine/crank some; does this change anything or require me to do any engine timing pins and TDC a cylinder before I re-install the CKP? I say no & no problems are created when turning the engine some while the CKP is removed.
