I'm attempting to install an exedy OE replacement clutch and flywheel kit purchased from fswerks. The problem I have is that my current flywheel is a dual mass flywheel, while the clutch kit is a solid flywheel and is much thinner than the OE flywheel. I purchased the flywheel bolts and the throwout bearing for the kit. The flywheel bolts are for a 2.3L engine and they are much shorter than the flywheel bolts that came out. I can't tell for sure if the throw length is different enough from the bearing in my current transmission versus the length of the new throwout bearing. I don't want to put it in and put it all back together just to find out the throw is wrong. So if anyone has installed this kit on a 2.0 L, could you tell me if this flywheel will work?
This is the kit that I purchased:
http://www.fswerks.com/collections/...e-quality-clutch-kit-ford-focus-duratec-fs107
It states that it fits a 2.0L engine, but doesn't say anything about required hardware to make this work on a 2.0 Liter engine.
The part number for this kit is a FMK1009 and comes with flywheel FWFMF06 all stated as 2.3L specific applications on the exedy website. I should have cross referenced part numbers and raised this question when I received the parts, but I didn't and now I have a car in pieces. I have contacted fswerks, but I don't expect to hear back before Monday.
