1 - 2 of 2 Posts
If I pull the radio is there any codes I will have to install to get it to work. If so where can I find them so I don,t have to go to dealer. I just purchased this car and have searched the manual for the codes it has a stuck cd in it. It is a one owner car so evereything is there such as manuals and etc.
So mote be it
your car's radio look like this?
You can remove it and re-install it with out any issues. It comes out fairly easy too, pop off the bezel that goes around it and the hvac. Then there are four 7mm (think thats the size?) bolts holding it in place in the corners, two on the left and on the right.
The hvac will still be connected to the bezel but you should still have enough room to remove the head unit. Then there will be two plugs that just pull off of the head unit.
1 - 2 of 2 Posts
