1 - 5 of 5 Posts
Hi. My car started then sputtered and died. Restarted and had to pump gas pedal tokeep it ru ning. Made it a coue blocks then died and will not start. Have replaced camshaft and crankshaft swnsora, new plugs and ignition fuse. While under car i saw a yellow piece next to a hose which is mounted on transaxle housing. Does anyone know what this is? I think a covering was over yellow piece since no way can it be so clean looking with all grease around it but cannot locate what part this is in my book. Any ideas will be much appreciated. Picture taken feom under car on deivers side looking up
Discussion Starter #2
Here is picture for above post
Sent from my LM-X220 using Tapatalk
Your fuel filter may be clogged or your fuel pump may be going bad. Do you have a check engine light?
w/ my magic bag
What made you replace the crank sensor? Not good to throw parts at it vs figuring out the problem.....
1 - 5 of 5 Posts
