Perhaps got broken while the car was being worked on by one of the shops sometime in the past. The plastic prongs that secures the cruise control actuator cable into throttle linkage is broken which causes the cable to shift around, pulling the cable and randomly causing the engine to rev up.
Which component do I have to replace to fix this? Hopefully not the entire cruise module as a "set".
