I've got a 2005 Wagon. I recently had to rewire the harness that goes from the car to the lift gate because the wires were cracked/melted and it was shorting my stop lamp circuit.
I've only had the car for a little over a year and so I took the battery cover off and noticed an INSANE amount of corrosion and foam around the contacts. It took some serious work getting the cables off. I cleaned it all up.
After finishing soldering the dozen or so wires back together and getting everything to work (even my rear wiper that hasn't worked since I've had the thing...yay...) I started it up and let it run for a bit. I noticed it idles SUPER low now compared to before I took the battery off. I read on FF that it re-learns how to idle after losing power to the ECU for more than 10 minutes.
So my question is, why did it suck so much at re-learning? Now when idling it feels like it's going to die and almost every time I shift from a gear to neutral to slow down it will die and I have to start it while coasting before I can get on my way.
Is there something I can check before doing a throttle cable adjustment to fix this?
BTW: No check engine light and no other issues with the car before or after I took the battery off except for this. I made sure the engine was hot before reconnecting the battery. The only thing to note is the massive heat wave we've been having here lately. It was about 95 degrees out when I finished up the work on the car.
