1 - 20 of 34 Posts
I have just recently bought some 6 spoke 2004 svt wheels and put them on my 09 coupe, and I was just noticed a grinding sound and the wheels are rubbin the caliper. Does anyone know of a fix for this problem? Wheels spacers maybe?
PARTS HUNTER
If they are.stock Svt wheel u shouldn't have a problem. 2009 see wheels are repainted eaps. And all of them are 17x7 +49 offset svts
wow, I'm surprised, can you throw up some pics?
PARTS HUNTER
U did torq down the lugs before driving right?
yes, everthing was torq'd correctly.
Here is a pic of the wheels I have.
This is where the caliper was rubbing on the rim.
This is the part of the caliper that is rubbing.
I know im going to need some kind of spacers, but which do I need and still be safe for everyday driving. Changing calipers is out of the question for me, since I just $300 on gettin a extra set of 08-11 red polymer coated calipers.
Focal Distortion
there are two different ways to fix this. 1) is get some 5-10mm spacers or 2) you could get the SVT front brake upgrade that will space the calipers farther out from the hub centerline and should clear the wheels.
I almost had the same problem with my ATS wheels. I think I had about 2-3mm clearance but it was enough. good luck
Grind it down Alil bit see if that helps.
Sent from my PC36100 using Tapatalk
Focal Distortion
This is all you need. 2-3mm.
Focal Distortion
No, I got really lucky. I would have been up a creek if they rubbed. These wheels are $500 each and there is no way I was going to risk damaging them. Also they are a 40 offset and spacers would have put them even farther out of the wheel well.
Based on the amount of rubbing shown in the pictures, I think I'd simply round the edge of that caliper brace a little with a die grinder.
Discussion Starter #13
I cant do that....Im puttin a set of red polymer coated calipers on. Im goint to try some 5mm H&R spacers. Hope that works.
PARTS HUNTER
We are talkin about the bracket not the caliper. Unless u coated the brackets too. That's really odd for it to do this. Other local member ran eaps/5 spokes on there 09's with no prob. But we did not have a 6 spoke to try even tho they have the same specs. Weird lol
Discussion Starter #15
yeah very weird.....I was weary at first cause ford always changes shit up between the first and second model year. i checked the wheel specs against the new model eap wheels before i bought em. its just majorly frustrating.
PARTS HUNTER
Actually u might want to get spacers front and rear the 08-11 have more fender clearance than 2000-07 might look better flushing it a little. Maybe 5 for front and 10 for rear. And for a little more try 10 in front and 15 in the rear to make it actually flush with the body
Discussion Starter #17
I actually ordered H&R 5mm to go all the way around.
I know one of the guys i work with put 6 spokes on his 08 ses sedan and he had to get spacers
I can't believe that you need spacers to run these wheels. I have the same ones and am waiting to mount them I guess I'll have to test mount them to see if I need spacers too :/
1 - 20 of 34 Posts
