21 - 35 of 35 Posts
SPIinDisguise very cool car. I thought about doing this project, but I have too many others already haha. I'm going to sell my SVTF since I don't drive it and its just takes up space in garage.
8 DAY HOMECOMING
Necromancing the thread I know but can you send me a pm with where I can get those parts also?
The actual parts you can get through Rebel Devil Customs. Email Mike.
Sent from my SM-G925V using Tapatalk
FF Affiliate
Lack of parts if something breaks, ecoboost blocks are cheaper, more plentiful aftermarket parts, more tuning availability, more reliable, easy to find.
Not sure I follow , I can buy the Zetec block for 100.00 all day long and its the same as the SVT Block , I can buy any aftermarket Engine or boost part for the SVT that can be buy for the ST and to make big HP I dont have to buy a 1700.00 High Psi Fuel pump or the POS standalone 3rd Inj , Tuning you have SCT and it gets the job done dont need anything else , More reliable we will disagree on BIG TIME , Only thing special about the SVT is the head and Intake , the Zetec block , crank is the same as the SVT , IMRC is still sold and cheaper off the Contour and I could go on and on , I would Turbocharge the SVT way before I thought about a ecoboost swap
Not taking away from yours because you did a super job on your swap
8 DAY HOMECOMING
Thank you, respect from one to another.
The $1700 HPFP is new tech, still being feeled out. But on ST stock fuel system you can make 420whp without an issue on a big turbo. With e30 on stock turbo you can hit 320, I feel it's pretty respectable.
Blocks may be interchangeable but finding good heads is getting harder and harder for decent prices. Escapè ecoboost blocks are 300-1000 depending on what mileage you want to have, internally built, etc.
After talking with multiple tuners, they had all said that the Cobb Accesport is 5-6 years ahead in tech compared to the SCT X4. Nothing against you but you may favor sct because you don't deal with the AP3 that often? I've heard good things about the HP Tuners N Gauge also.
It could be an argument that goes both ways.
FF Affiliate
Tuning I meant for the SVT , SCT is the only thing there is , I 100% agree Cobb and HPTuner is hands down better software for the ecoboost then SCT but neither offer anything for the SVT Focus
Yes i also would love to have more details on mounts, harness, axle and so on i have an 07 se hatch that needs rebuilt anyways and access to all the st parts i need
whats common failure point ive heard they have forged rods from factory and if i bought a short block would i be able to use the svt oil pan and head?
SVT oil pan is the same as all the Focus Zetec ones. SVT head bolts onto the non-SVT Zetec no problem. The only difference in the block itself is that the SVT is drilled for, and has installed, oil squirters.
ive heard the oil squirts dont really do much for the svt? any details on that
I'm not an engineer, but would say Ford/Cosworth wouldn't have spent the time and money to add them to a budget econobox hot hatch if they weren't useful. They certainly don't hurt things, and help shed heat from the piston.
FF Affiliate
You are correct they dont help , I remove them on my SVT Builds because they dump a LOT of volume and make the pump work a lot harder and higher oil temps , I have also found MANY in the bottom of the oil pans on SVT Engines that spun rod bearings , when the tube breaks off it leaves a good size hole that oil comes out of
21 - 35 of 35 Posts
