Man , you read about it and say I hope that doesn't happen to me. Well low and behold it has. My car has 40k and nearly killed me on the way into work. In EVERY gear I had to keep it under 2000 rpms or it would slip and just go nowhere. I drive 20miles to work, and it did this all the way to the Ford dealer where I took it in. They told me clutches were not covered under warranty. I said it only has 40k on it there is clearly something wrong.....They said too bad....must be the way it was driven. On the way out after having a fit the car seemed a bit better, it wasn't reving so high in the gears, but was slightly still evident.....does this sound like the clutch or another problem.....Any thoughts would be greatly appreciated! Would this be covered under warranty or Am I on the hook for a new clutch?[rant]
