1 - 2 of 2 Posts
Does anyone know where to get either an exhaust manifold hardware kit or individual heat treated bolts and studs? I am looking to replace the bolts and studs during an engine rebuild. The current bolts are 10 mm, grade 8.8. However, I do not know how long they are or how I should take the length measurement. Currently, there are 3 studs and 6 bolts.
I would order the hardware from McMaster. That's where I get most.
If you take the bolt out, you can go to any local hardware store and measure thread diameter and pitch if you don't have a gauge at home. Length is the underheard length (from the bottom of the flange to the tip of the shank).
1 - 2 of 2 Posts
