1 - 3 of 3 Posts
does my 04' focus with 2.0L engine and automatic transmission have a neutral safety switch? if so, where is it located and what does it look like?
Discussion Starter · #2 ·
did a bit more searching, and it may be called a transmission range sensor and is on the tranny. car won't turn over but all checks good on start system except havent checked the range sensor. it seems to also work the backup lights, and they work ok.
Don't have an Auto myself, but info from this site says there is a common issue of a switch at the selector lever area causing issues, ESPECIALLY when crud, spilled drinks etc. get down by the lever & gum up the works...
Inside the car, you need to remove the console cover for access...
Luck!
1 - 3 of 3 Posts
