Moved to MkI Focus section where you can find more foglight threads.
Std. lower grille has the fog locations filled in solid, only a car that HAD foglights would have holes in the grill for lights.
You would also have a headlight switch with a fog option (pull to turn on).
"Slot" description sounds wrong, would be a fairly large section at each end of the grille where they fit in.
