1 - 4 of 4 Posts
Hey guys new here, but I picked up a rough SVTF that I've been slowly building but if hit a wall on this one, so I went to go start it one day and everything powered on per usual. But when I went to go crank it nothing would happen so I replaced the starter, still nothing so I thought maybe ignition switch? Bypassed that still nothing, then I realized the dashes where the mileage should be. So naturally I assumed pcm so I checked the ground to the battery and the power diode both good so I ordered a replacement pcm but still no go, still not recognizing it in the system I figured I'd ask here before I pin this whole ****er out, would really like to avoid that but any input is appreciated
Discussion Starter #2
Figured it out, had bad factory grounds, all of them were shot, cleaned those up and put fresh bolts in runs like a top, crazy how something so simple can be over looked and cause so much trouble
1 - 4 of 4 Posts
