1 - 2 of 2 Posts
My 2003 ford focus is giving me a lean code. I replaced the o2 sensor and its still there. Maybe a manifold leak i sprayed it with carb cleaner and and it runs smoother at idle for a few seconds ant ideas?
Sounds like you found the issue....
If spraying ANYTHING near the intake changes the engine's running, you have a leak to deal with...
Narrow it down & repair, your issue SHOULD be solved...
Luck!
1 - 2 of 2 Posts
