Any help with any of the problems or all is more then appreciated.
First problem: The hatch likes to keep telling the car that the door is open. Makes all my doors keep trying to re-lock themselves when I am driving. Idk if its a bad lock or what exactly it is. The fob and the push button still work to unlock it. Yesterday the hatch wouldn't close. I had to slam it hard to shut. Update: Fixed wires in hatch, have to wait till I can get my car started and moving to see if I have fixed the problem.
Second problem: IMRC - Went to autozone, got them to scan my car for free. Came up with a code (P1518) (Intake manifold runner control stuck open) It functions. Before I start up the car. The lever sits near the firewall. After I have it started it sat pulled away from the firewall. After that I haven't seen it move no matter the rpms. I have no low end torque and the car slugs to go up hills. The lever isn't broken, and works freely when I move it with my hand. Is it the IMRC that's broken or could it be a short? I also get a clicking noise before I start the car, I don't know if that's related to the IMRC, but I hear it sometimes. Update: Did the repair on the IMRC, have to wait till I can get my car started and moving to see if I have fixed the problem.
Third problem: Front blinkers. The front blinkers don't work. The rear ones do. The Day time running lights do work. Its just when I turn on my blinkers the lights don't do anything. Its just the fast blinking pace like if you have a bad light bulb. The hazards are the same way. No blinking on the front. Both bulbs are good. as obviously they both light up to me turning on the light switch. Just I have no clue why they wouldn't work if the regular lights do work. I did check one fuse, but I don't know what fuses to check exactly. But I don't think this could be a fuse problem. Sounds like a wiring problem. I just have no clue. Update: NO IDEA
Edit addition to blinkers: I had a guy check to see if power was being sent to the blinkers to make them flash, and no power was making it to the connector. That was with the hazards flashing.
Please and thank you to who ever can help me with these problems. Even if you cant, thanks for trying.
Edit: Here are some pics of the problems.
Fourth Problem:
Hatch wires Fixed
Fifth Problem:
Disconnected piece, I don't know what it is or where it goes. Only know where it connects to.
^Around the area of the dsi lever
Sixth Problem:
Now this is how my headlights are spliced
Seventh Problem:
Next 3 pics are of the two wires that ran accross the headers. One of them was cut in half the other one was just holding in there. Looks like they run to something that involves my coolant?
Eighth Problem:
So I just noticed when I pulled the center console out. That one of the connectors to the airbag controls has been cut? What would this cause. btw the other connector was just laying in there
Ninth Problem:
The day I started working on the car, I took apart the hatch to see about the wires that run between the hatch and the body. They were all cracked and destroyed so I fixed them. My next step was to go fiddle with my IMRC. I removed my air intake, MAF sensor, battery, and battery tray. I then removed the IMRC. I took the IMRC apart to fix it. I didn't fully take it apart instead I bent the board out a little. Sprayed some electrical cleaner on it. Got a small piece of a nail filer so I could get the contacts, was quite easy the way I did it. But I then used a hair dryer on it. I installed it, I put everything back. I also removed my front blinkers and messed around with my headlights to see why the blinkers were not working. No solution. I went to start my car. And It would not start. I was puzzled. So the problem is after messing with all that stuff, the car wont start. Not even a click of sound. Nothing. Just the lights on the dash and everything else working.
The car doesn't have fog lights but the wires for it have the connectors and they dangle inside the front bumper. Also the two side bumper lights do work correctly, but then again, they do dangle just like the fog light connectors do.
Picture of the car as it sits right now. Has a 2010 Front bumper on it. Modded.
Please I really need help trying to fix this problem. If its fuses or relays, please tell me which ones and where to go for them.
Update:
Before I started working on the car. It did run, had a slow chugging starting problem. The IMRC was bad which caused me to have no acceleration. The car never liked to start up right away, instead it gradually gained rpms slowly. It had a leaky valve cover gasket. So the car DID in FACT RUN. I had the blinker problem also.
After fixing the hatch wires, I can not say it has fixed any problems because the problem I did have is when I'm driving the car would hit bumps and throw up the ajar light.
I still have the blinker problem, nothing has fixed it yet.
I have all the problems except for I cant fix or see if I have fixed anything cause since what ever happened has now made my car DITW.
Fourth Problem:
Hatch wires Fixed
Fifth Problem:
Sixth Problem:
Seventh Problem:
Eighth Problem:
Ninth Problem:
Update:
