Hello all. New to the forum, and not much of a car guy in general (so sad, I know), but I thought that perhaps I could get a little help with a headlight issue I'm having with my 2003 Ford Focus ZTS.
To make a long story short, I have a dead headlight. Went to the garage to get it replaced and found out, to my dismay, that the headlights are form an aftermarket HID kit that was installed by the previous owner. Time has worn the tags down, so I don't have a part number either.
As far as I can tell, it's a 6000K D2S bulb, although I am unsure of the wattage of the ballast (I have a suspicion it's 55W, though). The real problem is, these aren't quick connect bulbs; the harness is wired directly into the HID low-beam as well as the halogen high-beam.
I've scoured the internet and I cannot find a single replacement bulb or harness that matches what I have (I've attached images for reference). I have a hunch that I can replace the harness with one that supports quick-connect bulbs, but I have no idea if the ballast will support both high and low beams.
If any of you guys have any advice, information, or recommendations, it would help me out a ton!
Thanks!
Thanks!
