2002 ZX3 - Engine problem - video
Car has 104k on it, has always purred like a kitten, change the oil every 4k miles. Started it up this morning and was running bad, engine revving up and down from 500 to 2k+ rpms.. on the low end it would almost stall and did a few times.. rev it up and it would almost want to stall right when you hit the gas. Once it was reved to 2k or so rpms it ran there constant but still very rough, was making a bad knocking sound also when running at low rpms. any ideas? Just started out of the blue. Engine light is now on also, which never was before.
After a minute of this it started to run fine, like normal.. once in awhile it would feel like no power when you hit the gas then be fine again.
Started it tonight and same problems, running really bad, knocking.. rough etc.
