1 - 2 of 2 Posts
Can anyone suggest a good aftermarket replacement part for a 2002 Wagon? My wagon has a 185k on in it and I am having problems with the rear tires wearing on the inside. It has been doing this for a while. I was not planning on keeping the car much longer, but things have changed and I need to do some work on it. Any help would be greatly appreciated.
This is a common thing for wagons, mine does it to. The reason it does this is cause there is less weight over the wheel area. Things to check for is shock wear, track arm bushings (on the front side of the car) and the dogbone bushings (this is a short arm from the shock area to where the control arm mounts). Another suggestion is to get a lifetime alignment warranty, it costs a little more but in the long run it's worth it.
1 - 2 of 2 Posts
