1 - 2 of 2 Posts
Can someone clear this up for me please. I need to replace my fuel pump in my 02 SVT. It has a build date of May 13th, 2002. All the replacement pumps I am looking at have a "From May 22nd, 2002" date.
Does anyone know the difference or will these new pumps still fit my car?
Thanks.
C2H5OH
A newer pump will fit.
Though you will probably have to trim the inside of the tank. There are 4 retaining fingers that need to be trimmed flush. Not difficult. Utility knife and you can cut them out.
Lines and electrical do not change. It's just the way the housing holds into the tank that does.
Also, with the SVT you are best off buying a Motorcraft pump. I don't believe the aftermarket pumps are as large as your stock pump. It will support the stock power, but if you plan to go boost in the future it won't support the power.
1 - 2 of 2 Posts
