1 - 2 of 2 Posts
I've read though a few posts on piston ring sizes when fixing dropped valve seat. I've run into the same issue a couple others experienced. After measuring piston rings (which I should have done prior to ordering my parts), I found that I have the first design pistons with ring sizes 1.2, 1.5, and 3.0. I jumped the gun and ordered what was noted as standard ring sizes 1.5, 1.5, 3.0. Now, coincidently, I thought ordered just one new piston, but turns out I ordered the set that matches the new ring set.
If I replace all pistons, is there any issue with going from the first design which has a top ring size of 1.2, to the second design (new pistons) which will change the top ring size to 1.5?
As long as piston groove matches ring size you will be fine.
1 - 2 of 2 Posts
