I assume this has already been asked and answered but I can't seem to find a thread on it.
It acts like a misfire when accelerating. Basically a complete loss of power when accelerating in 2nd or 3rd, but then it comes back and will moments later sputter again. Repeats the process again after stopping and starting. Runs completely smooth at idle and eventually when up to speed will cruise at 70+ without a problem.
I started with thinking fuel, added an additive and pumped in 92 octane. Same problem. Changed plugs, no change. Changed wires and it improved but ended up with a misfire code, so I added dialectic grease to the inside of the plug wires and it improved. Today during a test drive it started again. During acceleration it acts like loss of power, comes back quickly, does it again, I shift to a higher gear, ease on the throttle and it may or may not stutter. I changed the coil tonight and the same thing happened during the test drive.
The only thing I haven't touched is the timing belt. It looked nearly new during an inspection but I may go ahead with replacing it.
Anyone have this condition and solved it?
