1 - 15 of 15 Posts
Ok so just recently i have been having this problem with my car. i have looked every where and cant find jack. ok so if i am very easy at the gas peddal the car runs normal. when i try to floor it it struggles, the RPM's reach to 3,000 to 3,400 and thats when the car starts to struggle. its an automatic transmission. I changed the filter and fluid 4 days ago and its still doing it. any help is welcome. oh and i recorded a video of the problem. here is the link
http://www.youtube.com/watch?v=ADS-Evvj0uw
Discussion Starter #2
it wont go past 3,000 rpm's looks like my plans for focus fest 11 has been ruined :'(
Hatch Nation #136
Are you sure it is a tranmission problem?
Nothing wrong with the engine?
nope. the engine revs up fine in parking and neutral. oh and i just had this new motor put in
oh and i also changed the timing belt, water pump, belt tensioner and belt this past saturday
Hatch Nation #136
Did the issue begin as soon as the engine went in? Perhaps something not mated correctly, or a wiring issue?
Discussion Starter #8
i had the new motor in there since August of last year. the transplant went well. no problems unitll two days ago. i just gave it another test run. it didnt do the problem as bad as the first video but i still feel like its struggling a little. the second video i am uploading is almost done. i had flashed the computer with a tune from SCT to see if that fixed the problem but it didnt. it only made the transmission shift hard
C2H5OH
My internet is acting up and I can't watch the second vid completely.
But I thought I spied the MAF being unplugged ...
Discussion Starter #13
idk if its the transmission really. its not doing it anymore. onlly once in a blue moon
Discussion Starter #14
ok so i found out what was the problem!!!. it was the elbow that connects the intake pipe to the throttle body. every time i would floor the car it would get sucked in to the throttle body causing the car to choke on high RPMS lol
my 2002 focus zx3 is doing the same thing you described. its fine on low rpms but if i give it gas to really get up and go it jerks. i replaced the fuel filter. and it was fine for the first 100 miles i drove but then it started to gradually do it again. not sure what the deal is, i really havent worked on mine like you have so i dont know wha the problem is. i lookon the internet before findin this site and got some suggestions that the catalytic converter might be clogged but i havent checked that yet. any ideas?
1 - 15 of 15 Posts
