1 - 20 of 40 Posts
Just picked up a 02 Focus SVT that needs maintance love.
Its in the shop right now getting a clutch / timing belt / new tires / and check engine light... I have only driven it a mile and it was pretty peppy. Oh and it only has 95k on speedometer... Its red.... with Black and red interior. Paint is in good shape other than the clear coat pealing on front and rear bumper... I got it for a good deal I think ....
Should I just have the bumpers resprayed or can they buff the clear coat off because the paint appears ok just alittle faded.
thanks don
Meh.
Welcome. [wave]
I guess if your really careful getting the clear off, that's all you really need to do. This obviously wouldn't fix any fading or stone chips that may be on the bumper, but if your not going for spotless show car quality, just a clear coat may be perfectly fine for you. Just make sure you clean the base coat really well before spraying clear coat becuase the exposed areas have probably had years of grime building up on it.
My svt is the same color and had the same paint issue on the rear bumper. I used the duplicolor spray paint in vermillion red. Sanded, masked, sprayed, then used the duplicolor clear. You have to look really close to see that anything has been done. 40 dollars total materials and a weekends time. Looks way better than flaky clearcoat. The prep work, sanding and buffing the finished product are the keys here
I didnt think of that [thumb]..... thanks.... Still in the shop[?|] getting my tags monday so maybe next I can finally drive it. Maybe.
Just got great news from the mechanic today..... My svtf only needs a timing belt, intake runner and clutch master cylinder that goes bad and all new motor mounts... And I also ran my VIN number from a link on this forum and now I know what my SVT was built with and the accessories that were included from the factory. I honestly can wait to drive it.
Primary Features
Build Date: 26.04.2002
Vehicle Line: Focus 1998-2005
Body Style: 3 Door Saloon
Version: Series 22
Engine: Zetec 2.0 VVT (170PS)
Transmission: 6 Speed Manual Transmission
Drive: LHD FWD
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: Vermillion Solid
Minor Features
Bright Red Interior
Waffle (A-C)
(-) Version Packages
Less Fleet Related Items
Hermosillo Plant Build
U.S. Sales
Less Special Equipment Package
Less Military Vehicles
'ST170'
Less Program Controls
(-) Wagon Equipment Group
Less Electronic Stability Control
Less Special Language Label
Owner Hand Book Pack
Less Canadian Provinces/Territories
Less Global/Auto Closing
Power Front Windows One Touch Down
Less Rear Side Window
With Fixed Rear Vent Quarter Window
With Tinted Glass
Less Heated Windscreen
With Heated Rear Window
With Full Floor Console
Front Floor Carpet Mats
Rear Floor Carpet Mats
I/P Insert - Metallic Finish
Non Illuminated Sunvisor - Drivers
Less Load Area Cover
With Load Retention Net
Honeycomb Radiator Grille
Less Roof Rack
Wide Bodyside Mldg - Body Colour
Rocker Panel Moulding - Body Colour
With Single Rear Wing Spoiler
3 Door Saloon
With Drivers Power Mirror
With Passenger Power Convex Mirror
With Body Coloured Exterior Mirror
With Tipping Front Passenger Seat
Less Front Seat Centre Armrest
Less Driver Tipping/Slide Seat
With LH Manual Lumbar Support
With RH Manual Lumbar Support
With Two Piece Rear Seat Cushion
Less Rear Seat Fold Down
With 2 Way Adjustable Rear Headrest
With Rear Center Head Restraint
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Driver 2 Way Pwr.Seat Adjuster
With Pass 2 Way Manual Seat Adjust
Exterior Door Handle-Self Coloured
With Self Coloured Tailgate Handle
With Leather Gear Shift Knob
Remote Deck/Tailgate Release
With Central Locking System
With Door Entry Remote Control Unit
With Int. Rear Window Wiper/Washer
With Variable Intermittent Windscreen Wiper
Less Heated Washer Jet
With Electric Slide Sunroof
Plastic Front Bumper -Sport
Less Front Bumper Extension
Rear Bumper - Plastic Sport
Retractable Rear Seat Belt-3Point
With Smart Drivers Airbag Restraint
With Smart Passngr Airbag Restraint
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
Style 1 Tether Anchorage Restraint
With Mini Aluminium Spare Wheel
17 X 7 Aluminum - Machined Finish
Cold Start -29 Deg C
Less Immersion Heater
Special Suspension
Less Rear Stabilizer Bar
4.25/2.88
Less Exhaust Pipe Extension
With Soft Feel Handbrake Grip
With Rear Disc Brakes
4 Wheel Anti-Lock Braking System
Less Anti-Spin Traction System
Less Pollen Filter
Fuel Tank Flap - Non Locking
With Power Steering(Fixed Ratio)
With Manual Tilt/Slide Stg Column
Leather Steering Wheel
With Speed Control
High Series Analog Cluster
With MPH/KMH Speedometer
With Tachometer
Dual Note Electric Horn
With Headlamp On Warning Chimes
With Reverse Proximity Sensor
Less Anti-Theft Alarm
With Safeguard Anti-Theft Sys(Pats)
Less Radio Pre-Equipment Pack
With 9006 6CD Less Telematics
With Audiophile Sound System
With 4 Speakers
With Smokers Package
With Halogen Headlamp
Less Daytime Running Lamps
With Front Fog Lamps
Header Mounted Courtesy/Maplights
With Load Compartment Lamp
Vermillion Solid
Less B&A Control Codes Issue 030388
Focus 1998-2005
Series 22
(+)"USA"
(-)"CDN"
(-)"PA"
(-)"BS"
(-)"AW"
Fun to see the official build list for your car.
Active bunch of members down your way, check out this thread:http://www.focusfanatics.com/forum/showthread.php?t=223938
Im really new to the svtf... thanks for the link I will check it out.
The previous owner put lots of aftermarket parts on it... rather than do preventative maintance... thats what Im taking care of now. What little I have driven it, its seems pretty peppy.
Discussion Starter #8
so far this week..
☑ timing belt kit replaced.
☑ new motor mounts all the way around.
☑ clutch master cylinder
☑ 4 new tires
overnighting new IMRC from Autonation Ford White Bearlake
Maybe I can drive my car tomorrow!!!!!
Good to get caught up on all that, covers a LOT of possible problem areas all at once & makes sure it'll keep working for you.
Discussion Starter #10
I have been living on this forum since I purchased the car last week.. This forum is a great source of information.. Its getting close.. [clap]
hi i didn't have much luck removing the clear coat from my hood but think the previous owner just re cleared it with some cheap ass stuff ,tried the product called "peeler" went right through the base coat ,tried a DA with 600 grit wouldnt cut it , ended up hitting it with 120 grit,then going through the grades back to 600, then just flat blacked it till i can get a respray ,the white showing through the peeling clear drove me nuts !
Discussion Starter #12 (Edited)
Well I have been driving the car a week now.. absolutely love driving it... Runs like a champ. I am going to replace the clutch before summer and go with a LUK replacement clutch. It rained today and the back bumper did not bother me much today. Now Im on the search for a complete back seat set brackets bolts ect for my car, the previous owner did the back seat delete to reduce weight. So the search is on[popcorn]
UPDATE... got the back seats installed this weekend... Car is almost complete... Clutch before summer and repaint of front and rear bumpers and hood in the spring...
Really love driving this car.
Glad you are enjoying it. I went through much of the same thing as you almost two years ago when I picked up my Silver 2003 5 door. Mine is bone stock but has all maintenance up to date and is just a blast to drive. I love being able to just put the pedal to the floor all the time and it holds the road great.
Enjoy yours.
Where is the link where you got all that information about your SVT? Post is please for those of us that don't have it. Thanks and congrats on the new ride. You are certainly taking good care of it. Post up more pics when you can.
Discussion Starter #17
I followed a link on this forum, but [dunno] cant find it now.
Argh! It was really cool information.
Discussion Starter #20
And the clutch can wait until the car needs it. Mine made it 200k miles...
Well mine only slipped once so far shifted from 6th to 5th and gassed it, so Im not gonna do that anymore, all other gears are fine. Ive gone from 6th to 4th and nothing but zooooooom. [loveff]
1 - 20 of 40 Posts
